'86 2004r differences?
spidereyes455
776
1,614
Northeastern PA
When I finally got and installed an 87 kzf for my 87 442 you could not feel any of the shifts. It didn't slip at all just really no feel to the shifts. I removed the servo and found the smallest servo I've ever seen in a 2004r ,noticeably smaller than any mcss or even standard 200. I installed a CK performance billet servo and now it has nice crisp shifts that will bark second with heavy throttle. Every thing I've read about the kzf says shift points are about 4800 mine are a bit higher 1-2 is 5500 and 2-3 3-4 are about 5000. This is a sub 80k trans that's never been apart.
8,088
17,308
I agree. My 87 442 has 23K on it, and it shifts quickly and firm. You can't really feel it per se, it's just that you know that it's from 1 to 2 right away without being very noticeable. Not sloppy, but not pronounced. It's a bit better than the typical slushbox. Rear gears probably help it. I'm sure you can beef up a KZF or any transmission for that matter with a bigger servo. Good info to know, I've never had a KZF apart. It's a wives' tale that probably has a bit of truth to it that the KZF's were toned down on the shift points as not to be critically harsh on the shifts. Whether the reason is true or not, who knows. But the fact remains that they did tone it down.
spidereyes455
776
1,614
Northeastern PA
87 kzf on left mcss/ generic 2004r on right
87 kzf
Mcss/ generic 2004r
gnvair
1,098
1,296
Thought GN's/turbos were the only ones with 2400 stall converters?
The D5 torque converter was shared between the different performance models. The stall speed variations were due to the torque output of the different engines with the turbo Buick producing the most torque and thus causing it to stall at a higher rpm.
Gonzo1970
898
1,302
Makes me wonder what 200R4 I have.. 69HurstOlds explained mine exactly.. Shifts quick and firm.. pronounced.. not your typical slushbox shifting.
-Gonz
8,088
17,308
A lot of factors can make the difference in how a transmission launches and shifts as well. If there's burrs or dirt, or not quite so tight tolerances/adjustments, or as mentioned, input torque to the converter.
It's not an exact science.
spidereyes455
776
1,614
Northeastern PA
-Gonz
The ID tag should be on pass side of the tail at the very rear. Being your car has an LG4 305 I'd almost put money on it being a CRF.
hoffa65
319
416
Atlanta GA
Thats a myth someone started many years ago. SS, 442, Hurst and GN had the same converter D 2400 stall. Now if you are at a junk yard and come across a Caddy limo year 85-88 look at the Vin. They came with olds vin 9 motor, 2400 stall D converter and a little higher shifting vavle body than a stock 200r4. I have the code for the trans written down, just need to find it.
From my experience all D5 converters are not the same. All converters have or had at one time and 4 letter code along with the PN tag on them. The 4 letter code breaks down as
1st letter = trans type
2nd letter= K factor aka stall speed
3rd letter= clutch type
4th letter = cover type aka clutch and lug type
D5 stall speed is pretty much the same,but the clutch rating and degree of engagement vary, along with the HO's having the NO poppet valve
Examples of some of the D5 differences are
84 HO = CB9D PN 8639265
86 GN = CBCF PN 8653420
87 MCSS = CBBF
86 MCLS = CG6F PN 8653154 (D6)
Attached are pics of the different TC's and a break down of the coding
84 HO
86 GN
87 MCSS
86 MCLS
gnvair
1,098
1,296
The torque converter info is interesting. From my own experience, the stall speed numbers only varied because of torque output. I put an 86 turbo Buick engine into my father's low mileage 88 Monte SS using the stock CZF trans and D5 converter. The Monte SS D5 converter stalled about the same (approx 2200 rpms) as a Turbo Buick D5. I had spoken to the guy who I have bought converters from several times over the years about the D5 converters. His response was that any differences between the factory ones were very slight nuanced differences. So from my own experiences the SS D5 performed exactly like the turbo Buick version.
