Hope I put this in the right forum.
*UPDATE*
*So I got the car running now (not really sure what I did), though now the carb is backfiring pretty bad and it seems sluggish. Any ideas?*
I recently got an 86 Pontiac Grand Prix, 305 v8 auto (Qjet carb). It ran fine when I got it, but had no muffler (or cat). I got a muffler on and when I tried to start it it ran really rough, sputtered, and then died. It took a little while to get it going again but it finally did and sounded ok.
About a week later I tried to start it and it ran really rough. A couple days later it wouldn't even start, just crank and crank. Timing is good as far as I can tell, (at TDC, distributor rotor is at #1), put new plugs in, it's getting fuel (won't even start with starting fluid), and I checked compression.
Cyl 1 - 150
Cyl 2 - 150
Cyl 3 - 140
Cyl 4 - 150
Cyl 5 - 160
Cyl 6 - 180
Cyl 7 - 140
Cyl 8 - 90
Cyl 8 isn't looking good but it still should start.
So after all the testing, I tried flooring it while cranking. It sputtered after a bit and then fired up. It ran ok, except the carb would backfire once in awhile while idling and whenever I would blip the throttle. I took #8 plug out to test compression again and after I got it all back together, it went back to just cranking and not starting.
Any ideas?
*UPDATE*
Cyl 1 - 150
Cyl 2 - 150
Cyl 3 - 140
Cyl 4 - 150
Cyl 5 - 160
Cyl 6 - 180
Cyl 7 - 140
Cyl 8 - 90
Any ideas?
