86 Chevy 305 no start
83gbody
156
Oxford, Ms
I need help getting my car started I replace cam, lifters an timing chain. I put timing marks together with number one piston up on compression stroke an put dizzy et number one piston. I've check the wires an timing over an over again but still no start it acts like it won't to start but don't when I pull throttle on carb it slows the cranking dwn can any body help me with any advice will be appreciated thanks
jrm81bu
3,000
48
Antwerp, OH
Right there's your problem. You're 180* off. When you line up your timing marks dot to dot, you aren't actually on the compression stroke on the number one cylinder, it's the exhaust stroke. You need to turn the engine over on revolution, then put the distributor in with rotor pointing to number one.
83gbody
156
Oxford, Ms
Thanks
83gbody
156
Oxford, Ms
Got another problem dizzy fires then stops
