CUTLASS 86 cutlass
Rktpwrd
Builder of Cool Shjt
4,166
23,915
Calgary, Alberta, Canada
Yes
Rktpwrd
4,166
23,915
Thanks bro. By any chance do you know where I could order them?? I also need some headlights and taillights also. Just bought my 86 this week and it’s in good shape it just need minor touch ups.
Some taillights are available aftermarket depending on the year and style, headlights should be able to be found almost anywhere. As for the mirrors, you could try posting in the wanted section here as I don’t believe they’re being reproduced yet.
Good luck.
  • Wow
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
I have a non-remote passenger in my parts bin. Just looked up the 8-digit GM number on the plastic gasket and it says 82-88 Cutlass. So your 85 should fit your 86 no problem.
69hurstolds
8,185
17,568
The 20215096 gasket fits either side, just an FYI. And Cutlass or Buick ONLY. Technically they'll fit 81-88 G47 Olds and 81-87 Buick Regal. Sport mirrors for these cars interchange.
LH (driver) side mirror glass if you need it.
And the RH. You can get a mirror cut from nearly any glass shop for the driver side although it won't have any certification markings on it, but the RH side has the convex mirror that makes things closer than they appear. Peel and stick. Again, if you have to.
