Saw Holdener thew a n* stsv blower on a 4.8 and made 600 on 11ish psi. The gt500 m122 I run and the stsv blower run the same rotors I believe.
I have 10 psi on my setup with the 2.75" pulley where he has 11 on a 4.8 with a 3" pulley. I have my 2.55" pulley sitting on the shelf I haven't run due to chassis (rear end) issues we're all aware of here....
I have 70 cubes on top of his test.
It's a bit apple to oranges but he ran 23 degrees of timing on E85, and I think I'm at 16 before I 'naded my diff last fall.
If I have 70 cubes and 7 degrees roughly on the table, I might be tapping on the door to 700hp. Almost a bit freightening....
I know 'if wishes were fishes' but damn, those are some stellar results. +30hp on corn without timing adjustment.
I've been eyeing those blowers for a while, and been watching his videos. Other than the packaging advantages of the blower, it's ceiling doesn't justify the total cost involved of using this blower... unless you already have the talent to DIY a blower base.
122 is pretty small for anything over 4.6L. Hell the 1.9L LSA blowers are pretty small for a 6.2L. This is where basic centrifugals make more sense as their airflow and charge temps are exponentially more favourable.
Richard is demonstrating what it can do, not what it will do. And that's what misleads a lot of people into disappointing results. His results aren't his process. Pulleys will make for interesting results.
Fortunately you know what you are doing.
I am now going to restrain myself from adding more timing to the TBSS.
