86 Monte Carlo. Swapping non A/C to A/C dash
Kelly McEnaney
12
Hello, is anyone willing to share a wiring dia OR know where to get one for the non-a/c and a/c Monte Carlo. I've pulled all the parts from a 84 MC and now need to swap into my 86. It would be nice to know what all the wires do and if my non-A/C car has any needed wires already in the harness . Thanks in advance.
Kelly
5spdCab
1,190
1,989
Tukwila, Wa.
Kelly
I am going through the same thing with my '78 Caballero. I have been writing about it in the "what did you do to your gbody today" thread. Just this last weekend I was prepping my future AC dashboard and wiring. My AC dashboard came from an '81 El Camino at the wrecking yard. I happened to find an '81 service manual in the car as a bonus. It has excellent wiring schematics, but the schematics that you can find in a Haynes or Chilton's manual are pretty good too. In fact, the Haynes and Chilton's will cover multiple years and can show you any changes between the '84 and '86. One of the things to also check is the instrument cluster connection if you are swapping to a different cluster. Another thing to check, would be the plug wiring to the vehicle's computer, to be sure that they are the same as your's. With mine this last weekend, I cleaned things up on the backside of the dash, tidying up the wiring loom and identifying the wires that the previous owner cut.
Hope this helps you.
Kelly McEnaney
12
Hi, thx,
I'll look for the manuals. All I'm changing is the A/C part. the rest of the car is staying the same.Mine is a SS but , back in the day, I ordered it without A/C. Now , as I get older I want to be comfortable with out all the noise of the windows and T tops. LOL
Kelly McEnaney
12
I got to thinking ,,,,
Does the A/C compressor not need to shut down in wide open throttle ? I cant see any switching for that to be true ?
Kelly McEnaney
12
Thanks all for the info.
During this process, I'm trying to fix some other little issues. One being , after the car starts, there is no power to
the bi-metal coil in the electric choke. Where does it get its power. ?
