Might pull the trigger on an 85. Supposedly a turbo car, but not much makes sense about it. Does not have 8.5, which could have been swapped out a long time ago. Has the 81-83 nose, which again could have been changed but its the same crappy faded paint.
Anyway, here is the good/bad with questions;
- Solid frame including rear rails
- Turbo/GN/T type hood
- Quarters are good except for lower rear which is nothing to fix
The bad
- Wrong nose piece/header whatever its called. Can these be found?
- No tailights, can these be found?
- Floor is bad in spots, can I buy half floors for G body?
Car is $750 USD with clean title. I think it is worth it only because of the hood.
The bad
