BUILD THREAD 87 Cutlass EFI build: 5/29/21-CRUISING
Streetbu
Know it all, that doesn't
2,488
Central NY
Ok, let's start over since you don't believe me. Screw the fittings.. Which brake LINE is larger? Should be the one going to the rear of the master cylinder which in turn goes to the front brakes.
Injectedcutty
G body LS mafia
Thread starter
Nov 24, 2014
5,778
Louisville, KY
Wellllllll.....I had issues with the stainless lines that go from master down to valve, so I'm using adapters and braided brake lines. On my master, the rear fitting is the larger of the two and I have it going to the rear already.
Injectedcutty
G body LS mafia
Thread starter
Nov 24, 2014
5,778
Louisville, KY
I just got back from ripping around a bit to see how the brakes feel from swapping vacuum sources only. I want to isolate the issue if possible instead of changing multiple things at once.
Tbh, the brakes feel better with the intake vacuum source than they did using the pump! I did some panic stops and such and it felt good. I looped onto the highway around the corner and quickly got to 70. I didn't hear the roar like I have been hearing. It rides a bit rough, but there is alot of poly on this car and everything is still basically new.
I'll consider it a win for today, and keep eyes/ears on it moving forward.
565bbchevy
8,337
Michigan
Does your pump store reserve vacuum in a canister, if I remember correctly yours was in the trunk with just an on/off switch and not set up to sense vacuum from a source
Injectedcutty
G body LS mafia
Thread starter
Nov 24, 2014
5,778
Louisville, KY
No. It was setup the way the instructions said. The hose went straight to the booster, but it did sense vacuum loss as it would build to stay at 22" of vacuum.
Injectedcutty
G body LS mafia
Thread starter
Nov 24, 2014
5,778
Louisville, KY
Also to note, I just went and checked the setup on the stock master and it's as depicted by Mike earlier. The larger fitting is on the front which goes to rear, smaller on rear closest to booster which powers front. I'm sure I'm overthinking it, just wanting to be sure I don't destroy parts and such.
malibudave
180
Houston, TX
Most stock type master cylinders have the rear port going to the front brakes.
If you don't have a hard pedal, you booster is holding vacuum.
Even though the booster may be holding a vacuum, that doesn't mean that it is not the cause of you having to pull the pedal back up with your foot.
Some aftermarket master cylinders can have the rear port going to the front brakes. I believe that Wilwood does this.
Smaller boosters produce less assist.
Larger boosters produce more assist.
Injectedcutty
G body LS mafia
Thread starter
Nov 24, 2014
5,778
Louisville, KY
After seeing Donovan post about waxing Olds Cool it dawned on me I've yet to wax my car since being painted, doh! So I checked with the expert and went to get a Mother's clay bar kit and some wax.
No joke, the detail spray that came with the clay bar smells like hot tamales and dang near had my eyes watering lol! Anyways, I went full Daniel son and clay bar'd and waxed the car tonight. It's nice and smooth now, and the wax definitely helped with the clarity some! Be nice to see it outdoors if the weather will cooperate.
That's it for now, here are a few pics as usual...
Texas82GP
Just-a-worm
6,763
Spring, Texas
What ever became of the master cylinder brake line issue?
Similar threads
G-Body Performance Upgrades
