ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Driving an 'as-is' G-body is better than staring at a parked 'will be fast' G-body.
Reactions: 7 users
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Definitely "getting there".
Lean into it, you!
Reactions: 5 users
69hurstolds
8,195
17,594
Might wanna get a clamp on that return line...… :) Looks great.
Do you have solid mounts? Reason I ask is that the angle/length of that return hose SEEMS a bit on the short side. Might be nothing, but will there be enough flex in the return hose to keep it from being pulled on when you mash the throttle? Just thinking out loud.
Rktpwrd
Builder of Cool Shjt
4,167
23,917
Calgary, Alberta, Canada
Just pointing out the obvious...
The return line is temporary as I don't have the right stuff here to make it look right.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
The return line is literally temporary. I had that line as a loop just to keep from spraying fluid everywhere! I have an AN hose end for the box side, just need to see if I can get the -6 line to go over the barb without breaking.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
She'll be a riot even without the hairdryer(s). Beautiful car man, you're getting close!
Thanks!!! I hate to set a goal and not hit it, but here goes. Holley's HQ is in Bowling Green, KY which is a 2 hour drive south for me. LS Fest is like Sept. 7-8th I believe(my bday is the 9th). My current goal is to have the Cutlass road ready for LS fest. With that being said, the wooshy things def have to wait. I just want to enjoy the car for a change.
  • Winner
Reactions: 9 users
