87 Monte Aero 1600 miles. Leaning drivers side rear
TomDisab
Nov 16, 2016
69
67
My "new" Monte is leaning left side rear about 3/4 of an inch lower than right side. Replaced shocks and springs. What's up? 1600 miles on the car.
69hurstolds
8,195
17,593
If you replaced shocks and springs and it's still doing it, then something is either twisted or bent. JMO.
MrSony
6,828
6,734
Des Moines, Iowa
Get the springs on right?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
park your vehicle on a flat surface and measure the ground clearance on the frame at each end of the C channel. If they are all the same then it's the body that is the problem, if they are inconsistent then it's the suspension
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Classic crappy metric frame build quality. Jam a 1/2" thick rubber spring isolator in there and see what happens.
L.A.X-RATED
1,387
385
83
Your aero has what Us city folk call a “Gangster lean” the only remedy being a must sell of trade(to me;))...I’d start with a spring,brake upgrade(while u are @ it?)and body bushing appointment...
