87 Monte Carlo LS
Montepit87
31
35
Hey there. I'm making a thread for a build of my first car I started 2 years ago. I got an 87 Monte Carlo LS. Speaking of myself, I'm a 17 year old out from Minnesota. I'm Enlisted in the National Guard with an MOS of Wheeled Vehicle Mechanic. ( will do an update with pictures)
I got for I think $200 bucks in total. Traded for it with some nissan that needed a MAF sensor. We got home on an oil change and some praying with a can of starter fluid. But long story short with alot of shortcuts and seconds guessing and yelling, the 305 didn't cut it. So the 305 ended up at a scrap yard. Bought a questionable 283 from a coworker of my dads. Didn't open it up except for the pan but threw a TBI intake on it without thinking. Didn't work out despite many attempts otherwise. Got an edelbrock torquer II intake threw that on and she would start. Cylinder number 1's piston decided to quit on me and crack. So we pulled it out and I brought to my moms and tore it apart in a night. We bought a running 350 and threw it in with the edelbrock intake as well as the edelbrock 600 that came with the car. Gave her a few spins around the block on open exhuast manifolds. Said **** it and drove it 2 hours to my mas. Since then I found out the transmission is going out. As well as the 350 is a 4 bolt main in great condition.
So plan for the engine build at this time is a set of camelhumps with the 1.94 and 1.50s. Might go bigger on the valves. Then I have the choice of two intakes. Holley street dominator tarantula style single plane or the edelbrock torquer II. I want to do a dual plane intake, I'm open to suggestions. I got two holley 600s cfm I haven't decided on what to do with and If I want to go bigger than that. HAven't picked a cam but I am doing a roller. Mostly cause the camelhumps came with comp cams 1.52 rollers. I want a forged crank just having trouble telling if either of my two are forged. HELP me. I also need a passenger turn signal lense and assembly.
5spdCab
1,190
1,989
Tukwila, Wa.
Hey Montepit87, welcome to GBF, from Seattle, Wa.
I am not highly knowledgeable on high performance, but many others here are. No doubt someone will have the answers you are looking for.
Tony1968
2,319
5,112
NW Indiana
You really don't need a forged crank but you can tell if it is cast or forged. I believe a cast crank will show sharper casting lines while a forged will look different due to forging process. Again not necessary unless you plan on spraying a ton of nitrous
Tony1968
2,319
5,112
NW Indiana
Roller cam is a bit much for a street car especially the costs involved. Again not necessary
What are your plans for the build? Street or race or ?
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Nope. A roller cam is perfect for anything.
-No break in
-No worry about oil choice
-More aggressive ramps on the lobes
The only downside is the cost, but it's well worth it these days.
Reactions: 8 users
Montepit87
31
35
I got two cranks to chose from one needs to be polished at least the other is still good. I want to shoot for about 350 to 400 horses.
Montepit87
31
35
-No break in
I agree but it will slow this build down quite a bit. But I want it bad. Flat tappet might be a better start though.
Montepit87
31
35
Street/Strip. Still on the fence about alot of it. I will be repairing the frame and florrpan soon
Montepit87
31
35
Couple of pictures from the past month of work on her. I'll find the other ones later. IMG_20200831_214753_190.jpg IMG_20200831_214530_533.jpg 20200913_204654.jpg 20200913_204648.jpg
pagrunt
9,155
15,321
Elderton, Pa
Nice to see someone from this century getting to our cars & getting dirty working on it. Now how did you get conned into being a wheeled vehicle mecanic, chicks dig dirty old 11B grunts. Ask my wife when she's not pissed off at me. ;)
Reactions: 5 users
