87 monte carlo (question)
Bowiemontecarlo86
693
16
Tampa fl.
Yup it should
-83MONTESS-
4,570
967
Bellevue, Ohio
I believe they all interchange except the very early 80s and late 70s because the wiper switch wasnt on the column like the newer ones are.
565bbchevy
9,614
12,683
Michigan
I think it depends on what year Cutlass, though I believe many years are physically interchangeable I think in 84' and up columns they changed the wiring for the wiper switch (and maybe other things).
I changed my 83' column shift for an 88' floor shift and all though everything bolted and plugged in like the original I could not get my wipers to work and I found out they use a different wiper switch and the later years also use a smaller style wiper motor that does not interchange with the older harness plugs.
