#1 The bumper reinforcement is also from Glasstek. It is molded like original but in fiberglass. I mounted my original steel bumper to compare and it was the same.
The lightweight struts to replace the bumper shocks are a problem. They were a bit longer than stock. Plus stock had shims. Pretty dumb to make them longer than original. Seems like shorter would be better and then we could shim to compensate. So I cut and rewelded them 1/2" shorter but it seems like it needs to be even shorter to get the bumper closer to the grille.
I have reproduction return springs which pull the grille forward but it's not truly forward. It swings up in an arc. In the pic there are 1/4" stoppers to keep the grille flush with the header panel. Without stoppers, the gap get smaller but the bottom of grille will be higher than the top of bumper.
#2 I have a center filler to get rid of illusion of gap but still wondering what IS the proper gap.
#3 Prepared to deal with the 1/32" off here and there, just need to know where and what is out.
Factory had variance all over the place, it wasn't like the new cars of today.
I swear there had used to be a post in this thread here of someone showing the front of their car, and the gap, and theirs looked right.
Your bumper is going to be tucked over the fillers, and it's going to cover that little tab on the fillers that extends forward near the grille to a point where you won't see it.
When the 'center' bumpernfiller is installed, the v shaped silver plastic, that will not be visible either as the grille is going to come all the way up to it.
Take a look at this picture. Everything should tuck up underneath.
On the cars that saw 100k+ of road use back in the day, with bodies flexing and things moving, you used to see the bumper fillers touching the inside of the bumper shell usually on the outside edge, and, factory tolerances being what they were, the bumpers sometimes toughes the corner edges on the fillers up top where things tucked underneath.
Made snagging used fillers out of the junkyard a real hard find.
But that picture would've been one example of a factory tolerance. It's a 50k mile car.
If your grille isn't resting between the 'wings' on the top semi flat surface of the bumper that sweep towards the headlights, you're too far forward
