88 Cutlass Supreme Classic
snowball
41
Hi all
I have a 88 Cutlass that I bought new and still have orginal except for the rear deck lid and that came from a 1984 Hurst Olds. Just wanted to know if anyone knows how many of these where made? Also have 1970 W-31 Is there an easy way to insert image? Never mind I think i found it. Thanks
A base cutlass isnt worth anything value wise to a collector. The only cars that are are 442s and hurst/olds cars with low miles. And even then they need to have lower number factory options to bring any real money.
He still does not know how many were made. As a side note I found a 403 from Mondello for about $6500 that will fit without in the engine compartment without any trouble and it will look stock. Will work with the 200r4 and all power equipment. Does that sound like a good deal?
Don't get anything from Mondello. A 403 fits exactly in a 307's place, mileage will not be much different if kept mild. You will not miss the 307 at all. Add hardened pump rings and stiffer spring, big shift kit with bigger boost valves(Trans Go,CK), billet servo, deep pan and an extended 700r4 filter. Mine has held up so far.
