BUILD THREAD '88 Monte Carlo SS w/ LY6 6.0 swap
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
I've seen the pics haha. Made me want to do mine!
Nothing but boring *ss sanding lol! I just keep telling myself that in the end it will be worth it! So far the results have been very satisfying which helps to ease the blow of all the hours of prepwork.
I'm actually outside right now sanding my front turn signals in prep to repaint them! 20170710_233542.jpg
SStavin
87
189
33
Chicagoland
Had some trouble finding a shop that would work with the 36 spline yoke for the 6L90. Did end finding a local shop; Midwest Driveshaft. Went with an aluminum 3.5" shaft, 4L90/6L90 yoke, and standard GM 3R rear yoke for the 8.5" 10-bolt.
Also started laying out the harness so I can start identifying connectors.
7,987
18,693
Cool idea on laying out the harness and cool Zeppelin poster.
SStavin
87
189
33
Chicagoland
Got the fuel system in order. I had a supply/return fuel system from the Holley Stealthram I had previously. Removed the return line and went with the return-less system using the "Corvette" fuel filter (LS universal fuel filter kit from Summit) single feed to the Vortec fuel rail.
Installed the water pump and truck Power steering pump to the original gbody lines. The fitting from the original gbody PS pump screwed right in. Still have to figure out what to do about the 3rd PS line. Must have been from a hydro-boost set-up?
Removed the TCM from inside the trans pan to send out for programming
Rear bumper studs, speed-nuts did not come off very happily when I removed the bumper so I drilled out what was left and improvised.
OCD set-in at some point so I scuffed and Painted the horns
....and the front wheel-well pieces
SStavin
87
189
33
Chicagoland
Little by little the project continues. Getting things snugged down in the engine bay. Mostly situated the engine harness
Getting into and cleaning up the wiring. A bit intimidating at first but I'm taking it slow, tracing, eliminating some old, andadding some new.
Mostly eliminated the Racetronix Hotwire Kit that I had installed as it became redundant.
Fabbed up a mount out of an old retail display fixture for the ECM, power distribution, and fuse block. Mounted behind the glove box.
Even had some extra time to re-spray the fender liners
7,987
18,693
Good progress!
19,992
Very nice!
