93-02 camaro posi in 7.5?
Jason14x
26
Hey guys question for you. I have seen a few videos and read about guys using the 93-02 camaro posi unit in our 7.5 rear ends to upgrade the durability? . Anyone do this or know of anyone who has? Would really like to just keep as much of my Monte intact as I can and my LS is gonna be pumping between 400-450 when I'm done. Dont plan 9n any racing or drag strip stuff,.so any advice on this would be great.
Jason
64nailhead
Goat Herder
3,344
Upstate NY
It will require different axles. Either a set of custom axles, GN axles/442 8.5" axles, or a set of 28 spline 2wd S-10 axles. The last option requires you to make a 3/16 or 1/4" spacer to stick between the brake assembly and housing.
carnutjw
410
Pretty sure the 98-02 style Torsen differential is preferred over the 93-97 cone style, but here's one option for axles:
64nailhead
Goat Herder
3,344
Upstate NY
Jason - he ^^ is spot on.
We have a spare rear in the basement for our cars - the Torsen carnuts is referencing (with S10 axles), but the axles he linked are 5 times better. That diff ran for a full year at just under 500 wheel HP. It was tough enough and never gave up. The Torsen deal takes some getting used to, but once you do, it's fabulous. Basically, it's a budget Detroit True-Trac.
If you make a real 450 crank HP with your motor, then the 1st time you light it off out of a roll be ready to drive because a Torsen will require it.
Jason14x
Thread starter
Mar 28, 2021
26
So it grabs hard ! Like it. Glad I did the research!. I may have to go junkyard hunting ! Or just buy a new one !
64nailhead
Goat Herder
3,344
Upstate NY
I think you'll find the price of new one somewhat outrageous. If you find one in a junkyard, then I say good for you. They are few and far between - watch Craigslist, FB marketplace and Ebay.
Finding a 3 series (3.23 and numerically higher) is not easy.
WanaBa442
431
New England
i found a NOS Torsen one for short money on C/L last year. Series 3 too. (y)
They are out there, ya gotta keep looking.
64nailhead
Goat Herder
3,344
Upstate NY
Agree - there is not big demand for them because of the 7.5 (7.625) nomenclature, but they are way tougher than an Auburn, Eaton or any other clutch style posi in this size. Extremely safe at 450 crank hp with a good axle.
WanaBa442
431
New England
For the $$ I couldn't pass on it. It's on the shelf with reserved space next to it for upgraded axles and an install kit and gear set.
Really would like 3.08's with the 260 and 3 speed auto, but no joy with the series 3.
3.23's are not much more of a jump but the little 260 would be singing on the highway, prolly with a tune I wouldn't like.....
Guess I need to put the motor pile o parts together too
G-Body Performance Upgrades
