94 camaro z28 rear
ham1974
240
66
I found some one parting out a 94 z28 locally. What type of posi would be in the rear? I have read they had a G80. What type of carrier is the g80?
Oct 14, 2008
8,806
7,746
Melville,Saskatchewan
Should be the Torsen 7 5/8" posi with 28 spline axles.
80ELCAMINOFLAKE
2,685
14
38
California So Cal
Also make sure your axles are 28 spline too :D
jrm81bu
3,000
48
Antwerp, OH
G80 is an option code(rpo) for a posi differential. Not a type of posi. That said the other previos post were right on. It should be the Zexel-Torsen style posi and to install it you will need to get a set of 28 spline axles for your rear.
ham1974
240
66
Thanks for the reply's. I did not know if it was a torsen or not. Is there a reason most people say too look for a 98-02 rear for the torsen?
