99 blazer front brakes
kuruption109
2,886
17
38
highland, CA
im lookin at pickin up a set of front spindles rotors and calipers from a 99 blazer 2wd will these work on my 81 malibu?
JBreu
2,168
20
38
Livonia, New York
Kuruption, 1998-2002 all had what your looking for.So long as they are of the 2 wheel drive ones. Hope that helps a lil :)
axisg
2,685
2,354
YYZ
grab the spindle and everything attached including the rubber flex line. Check the bearings for noise before you fork over any serious cash as they are expensive to replace 8)
85GPLef41
2,210
159
Colorado
X2 BUT if you have some good ones then it lends to a C5 front brake and caliper swap i am using them to do my early C6 13in and rotor and caliper swap using a simply made adapter bracket and a little clearing on the spindle arms for the bolts which i have pics of... :wink:
kuruption109
2,886
17
38
highland, CA
post the pics
85GPLef41
2,210
159
Colorado
Here are the pics of the clearance grinding done. i did it so the bolts sat straight with no binding sorry for the large pics...
before pics of the calipers
After getting the spindles and control arms powder coated and mocked up still need to get the calipers powdercoated though.
LSCustoms
1,726
13
they just had a half off sale i just missed again, have you got the spindles yet, i may be going to the junk yard again in the morning...
85GPLef41
2,210
159
Colorado
I managed to get a second brake set up for "future" G body project. I payed 40 dollars for the kit it just needs a hub so not too bad IMO.
