The 73-77 rears are a different animal than those before and after them and don't know if anyone has put one in a g body or not. I've not seen any upper arms to adapt one to fit our cars either.
I mistakenly bought one, and it would have been a royal pain making it work. I later found a 70 Monte 10 bolt but I used to spring perches from the 73 as they were the over-the-tube style. Lower control arm brackets would need to be cut, moved and welded (and only a 1/4 inch, but it was enough to cause some bind) the upper ears also sit at a different angle, so even the UMI swap arms don't work.
That being said, anything is possible to do. You could technically make it fit, you pretty well just need custom control arms, a decent welder, time and patience.
It definitely won't be a weekend swap.
