New guy. Scot. Previous G-body owner (3x 2-dr cars; 3x El Caminos). I have been on the MR forum for years but it's not very active & this forum seems to have more recent traffic so I signed up because of this thread.The one on my '89 TTA went bad and they aren't $53, they are unobtanium.
I fixed it with a 1/2" 8-32 Screw, Nylock nut and a washer. Costs $1.18 to fix 8 cars @ Menards.
I have the control panel loose & was hoping the screw/lock-nut method would get me by. If it worked vs. sourcing a new part, I figured I would leave it @ that. Looking @ it, I can't really see where it would 'squarely' hold both sides for a better seal unless you drilled a hole through the center. I can order a new one from Summit (return/exchange ease). But they list it as over a week wait for it.Just looked thru the order history from napa.. and they dont list the control valve anymore.. Nor does advance auto parts...
Looks like you're stuck with RockAuto at $57...
As far as the bolt/nut fix, I don't know... I wasn't tearing into it twice in case it didnt work.. and replacing it worked for me.
-Gonz
Sweet Malibu Scot! No experience with the screw fix, I bit the bullet and ordered the new control valve. Works like a charm now. Good luck!
try this,it's a cheap fixACDelco 15-71389 WOW these must be getting real scarce, the price has double or better in a year. I suffered through heat on all summer last summer and won't do that again. I've found no other leaks in my system and am down to replacing this part. The price is steep for AC Delco piece of plastic uch
