Summer is coming. Here is how to repair and service A/C and convert from R12 to R134a. I also have a video about retrofitting A/C after an engine swap, and how to check an A/C compressor clutch if you're interested. Links below. Hope it helps!
The real answer is, not really. If you know enough to ask the question you can appreciate changing the hose lengths may affect the volume of the system. Since the system operates based on containing a specific amount of refrigerant, a change in volume will effect operation unless balance is restored. In a stock application, adding a longer line would make the volume you put into the system incorrect. Since this is a custom installation anyways, that is partially out the window. The stock refrigerant measurements now become the baseline for some educated guessing in a modified system anyways. IMHO, the real downsides would come in when you have the cold side lines so long it cools the engine bay before getting to the evaporator core. But some insulation could mitigate that. However, I don't think that becomes a real thing until you are talking about extending the lines yards rather than inches. I'm sure there are many factors I haven't considered, but for now, I'll stick to the idea that it won't make much difference in a custom system since you have to determine base refrigerant servicing level anyways. Good luck.This is awesome, thank you!
Is there a limitation to the length of hoses for the a/c system? It seems you could get real creative with routing, but I am wondering if there is a downside to having too much length.
I understand the volume difference when converting to 134. About 20% less. What about the higher pressures on the high side with 134 in a stock system that has been flushed, hoses replaced, evap, replaced? My high pressure is going to 250 when ambient temp is 95 outside. Seems high. I didn't add a HP cutout. My duct temp is only 55-60*f. I thinking to bleed out a little to see if it would get cooler.
83 HO.
