A few overhaul pics, more to be added in time
DelOhio
200
Delaware, Ohio
Picked up my Cutlass a few weeks ago, she had froze calipers and the rotors'n drums needed turned and all four shoes needed replaced. So while I had the breaks off I figured I'd sandblase the rust off the parts and rehit w/ high temp paint.
To put her back on the road I'm gonna need to finish the breaks, drain the rear end and refill. Oil change & plugs, along with transmission fluid & filter change. I'll be adding pic's as time goes by of my build/restoration
Rotors after being turned but before they were sandblasted:
Rotors after I blasted them:
Rear diff. cover after I blasted it:
More updates/pic's to come
supercrackerbox
385
2
Lincoln NE
I don't remember, do these discs have replaceable bearing races? If so, I'd plan on doing that. And make sure the insides are SUPER clean before reassebly.
Just saying.
dan2286
2,233
4
Cleveland, Ohio
Just saying.
Yes, they are replaceable.
DelOhio
200
Delaware, Ohio
Just saying.
Baught the bearings, I will be replacing them before they go back on the car.
Heres a pic of the diff cover back on after paint and new hardwear:
And here is a Pic of the break dust sheilds before I blsted & painted them. They're out in the shop drying now.
DelOhio
200
Delaware, Ohio
Dust Sheilds & rotors are done drying and back on with good bearings & new rubber break lines. I went ahead and painted the new calipers red, I thought it would accent the car well and now that the wheels are back on Im happy with my choice. Sorry I have forgot to bring my camera out to the shop the past few nights, more pics to come.
DelOhio
200
Delaware, Ohio
Wheels Back on.
Replaced transmission fluid gasket & filter
Sand Blasted, painted and replaced the hardware for the lower crossmember
Valve cover gasket and I had to weld and reseal the filler back on.
Replaced some of the hack wireing that came with the car
More to come
DelOhio
200
Delaware, Ohio
Silly minor updated pics.
Replaced all the Radiator hoses and thermostat, plugs wires & both cover gaskets. That passenger side was a b*tch.
Tinted the quarter windows, haven't had any time to tint the rear.
Its time for new tires, trying to figure out how wide I can get on the rears.
I'll keep adding pics as time goes by.
:friday:
Oh yea, the thermostat housing was a nightmare to get off and back on with that stupid little tube on the passenger side of the housing on it. Glad its done but F*CK
DelOhio
200
Delaware, Ohio
Blake442 said:
Assuming you have 15x7 rims, I'd go with 255/60R15 in the rear. I wouldn't go any wider than that without stepping up to a wider rim.
No they're either 14x6's or 14x7's. More than likely x6's knowing the original owner.
Larryg
131
western Mass
I wanted to sell my car after replacing the thermostat! I still have A/C and everything is stock so there were so many hoses and wires I couldnt even find the s o b for a while. Then that little limp dick extra hose thingie wouldnt allow it to be moved. Every hose clamp was facing an impossible angle to get a screw driver or wrench on. I seriously wished I had removed the entire intake manifold before I got started. My back hurt for 3 days. I remember changing these in 10 minutes 30 years ago.
By the way, nice upgrades on your car! I put 265/50/15 on 8" rims and they rubbed a bit. It looks cool but I dont need that much rubber anyhoot.
