? about amp fuses
Doug Chahoy
2,565
2,663
This question shows what I’m not sure of. I think I know the answer, want to hear it from people that know TONS more than me about auto electronics. Here goes, I’m installing a Lokar LED shift indicator. It says to use a 15 amp circuit. Ignition hot. Is it ok to use a 20 amp or should I put in a 15 amp fuse. You can stop laughing now, I’m learning this stuff as I go. I couldn’t believe what all is involved in this install. Install a special nut and cable arm on the trans arm, run a cable to the right side of every GM transmission except a 400, to a sensor box that you mount to the trans pan bolts. Then you hide they’re ( secret) decoder box. I put mine in the glove box. They have every position where every wire is to be attached ( thank God) well labeled. Theres about 15 different wires depending on your trans to connect to the decoder box. I’ll be wiring into the box and testing today. That’s why I’m asking the amp question.
Doug Chahoy
2,565
2,663
This is all the parts that don’t show
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
15a seems high, but 20a won't hurt it. Fuses are for protection from shorts- they blow before the wire or component burns up. You're good; send it.
*I say 15a seems high because I would think the indicators are LED(?). If so, the unit should run on something as light as a 5a. If they recommend a 15, do that, though.
Doug Chahoy
2,565
2,663
A th350 that I eliminated everything to do with the column shifter . So I’m installing this shift indicator kit.
g0thiac
939
582
20 is fine for a shift indicator, it just means more current can pass through before the fuse blows up.
It's not like you're dealing with a circuit that would make the vehicle a problem to drive, in a worst case scenario type of situation.
So honestly, a 5 amp difference won't be a huge deal, but anything more might damage whatever you're trying to install. It's rated at 15 amps for a reason, because that's what the circuit is designed to handle. Now, obviously any fuse would be better than nothing, but still it's best to use the proper rating considering a pack of ATG fuses are like 5 bucks dude lol.
Doug Chahoy
2,565
2,663
I have a crap load of fuses. Put a 15 in, got it all together and programmed
