86 cutlass supreme originally had olds 307 now has olds 350. Does anyone know where the brown ground wire goes to for the ac clutch relay. Ac clutch engages when it is grounded
credit goes to 69hurstolds86 cutlass supreme originally had olds 307 now has olds 350. Does anyone know where the brown ground wire goes to for the ac clutch relay. Ac clutch engages when it is grounded
Sure just ground it, that's all the ECM does.Is their a way to hook it up different so it works without the ecm
>>If you were to bypass the ECM what will increase the idle when it A/C is on?Is the ECM still running the engine? If you were to bypass the ECM what will increase the idle when it A/C is on? Why are you trying to run the A/C with out the ECM?
Making the A/C work would be fairly easy if you are not using the ECM but would need more info first.
There's that, too.Ac will only be used for cruising so if I wanna haul i could just shut off the hvac from the controls
