Ac compressor and bracket help
bertscova
101
36
I have a 1979 malibu originally a 267 v8. It had a older 400 v8 when i bought it. Now it has a 383 stroker with a newer one piece rear seal block and a set of aftermarket aluminum heads. The car is a factory ac car and still has the condenser and ac box. I need pointed in the right direction for a compressor, hose and brackes. Driver side mount. Any help would be appreciated 20180406_175334.jpg
19,992
If that is your engine in the picture.
Then whatever bracket setup you already have buy the AC bracket for that set
9,611
12,668
I believe this is the same bracket set up as the kit you posted if that is all you need.
A lot of these kits use Alan Grove brackets to mount them.
7,986
18,691
Im look at this kit anyone use them
That looks like a nice kit. The Sanden compressor is a nice piece. You might be able to piece it together for less but I don't think you will be disappointed with that kit as long as they are quality parts and it is in fact a Sanden compressor.
