1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Ac / electric fan help
Discussion in 'Electrical' started by Zacheus, Sep 13, 2017.
  1. Zacheus
    Zacheus Not-quite-so-new-guy
    Sep 2, 2017
    4
    I have a 1982 Monte Carlo cl that I installed a Holley sniper efi on been running great since December. I’m currently installing the ac back on the car and need a little help. The Holley sniper has the ability to turn my electric fans on when the ac is switched via a ground input to the efi unit. My question is can i splice into the ground connection on the ac compressor plug ?
  2. ldr
    ldr Greasemonkey
    Sep 16, 2016
    237
    178
    Sarcoxie, MO
    My sniper don't have that function. It has a AC kick feature that opens the IAC a touch to help with idle rpm from compressor load.
  3. 454GrandPrix
    454GrandPrix Master Mechanic
    Jul 27, 2016
    289
    380
    Lehi, Utah
    Maybe, depending how the car triggers the compressor. If the car turns on the compressor by sending a ground signal, then you can tap into this same signal and send it to your EFI. If the car turns on the compressor by sending positive voltage to it, then you'll need to expend more effort. (I don't know which way it works because my A/C system is not functional.) If the latter case is how it works, you could install a relay which is triggered by the A/C voltage but then merely sends a ground signal to your EFI.
    Just a thought.
    • Agree Agree x 1
  4. Zacheus
    Sep 2, 2017
    4
    I remember seeing it when messing with the software on my computer. I'm not 100% sure but I believe it's tied into the iac kick fuction which is a ground input into the sniper. So to get the iac fuction to work I would just splice a relay into the positive voltage side of the compressor and use the ground side as a input into the sniper?
    Thank you for your help
  5. ldr
    ldr Greasemonkey
    Sep 16, 2016
    237
    178
    Sarcoxie, MO
    I used the 12V wire that went to the idle solenoid on the old carb. I ran it to the relay for the idle kick and to turn second fan on with ac switch.
  6. ldr
    ldr Greasemonkey
    Sep 16, 2016
    237
    178
    Sarcoxie, MO
    Are you using a laptop with the sniper?
  7. Zacheus
    Sep 2, 2017
    4
    Thank you that's what I was thinking as well when looking at the service manual. Now I know I would run the solenoid wire to #86 on the relay and how would I wire the other termanals?
  8. Zacheus
    Sep 2, 2017
    4
    I have the software but haven't really used it.. I like to play with it to better understand how to use it when needed but i have taken a couple data logs and it's very impressive
  9. ldr
    ldr Greasemonkey
    Sep 16, 2016
    237
    178
    Sarcoxie, MO
    30 and 85 to ground, 87 to sniper. Set ac kick to about 5% then tweak it from there. I wouldnt change much until you get a few hundred mile on it. Honestly not sure I would even mess with the ac kick. If you set idle and IAC correctly it wont need it. I was wondering why both fans come on, on my car when I turn ac on. It s programmed that way from factory. Looks like the only way to fix that is to buy the dongle for a laptop.
    #9 ldr, Sep 13, 2017
  10. Zacheus
    Sep 2, 2017
    4
    I agree and the only reason I want the iac kick feature is for the fans or will they come on with out wiring the kick?
Loading...
Share This Page
