AC vacuum control valves
Cajun83HO
Cajun83HO
Aug 3, 2016
99
Louisiana
On my 83 Cutlass, I'm looking for the vacuum control valves on the back of the AC control panel. I can find the 9 port and its on order. But I can't find anything on the 2 port that is connected to the temperature lever that controls the heater valve. When on MAX it allows 100% vac to heat valve to keep it closed.
Can Anybody help me find the two port?
TURNA
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
11,003
Socialist NY
:popcorn:
69hurstolds
69hurstolds
3,857
You are in luck!!!! Sort of. It's part number 7897420 or AC Delco 15-7975. For whatever reason, I tried looking for this before and couldn't find it. But I looked again and found the part number for BOTH the 9 port and the 2 port. 2 port has been discontinued for a good while. 9 port can still be found under p/n 16037778 or AC Delco number 15-71389 or aftermarket parts equivalent. GM list price for the 9 port is $141.89. As far as I know, the 2 port isn't available aftermarket. Saw a few of the 2 port ones on ebay and from various sellers.
BTW- they used the SAME 2 vacuum switches in the Cutlass from 78-88, it just doesn't show it here since the book only went back to 1982.
69hurstolds
69hurstolds
3,857
Another source is 1991-1993 GMC and Chevy VANS with A/C. They use the same 2 port switch. So if you found one in the junk yard....
TURNA
TURNA
Jul 24, 2009
11,003
Socialist NY
69hurstolds
69hurstolds
3,857
link 2 port?
Ebay...type in the following p/ns…..
7897420 or 15-7975
Want me to install it for you too? Or you want me to empty your PS fluid? :)
Reactions: TURNA
TURNA
TURNA
Jul 24, 2009
11,003
Socialist NY
Both plz if you have the time!
Thread starter Similar threads Forum Replies Date
M Vacuum Canister Reservoir Wheels / Tires / Brakes 4
W Vacuum selector switch Cooling / Heating / AC 6
G 1980 Malibu classic landau chev SB 267 vacuum routing General Discussion 13
harvtown REGAL need vacuum hose diagram 1978 3.8 dueljet Fuel / Air / Boost / Emissions 1
P Detailed vacuum hose pictures General Discussion 6
Z Vacuum Ball General Discussion 4
rogus Where to buy vacuum pod 81 Elky Cooling / Heating / AC 0
Buford T. JuSStice No vacuum to HVAC system, stays on defrost Cooling / Heating / AC 17
kustomkyle Replacement air cleaner vacuum actuator, 307 Olds. Fuel / Air / Boost / Emissions 4
dickeymoore Holley vacuum secondary???'s Fuel / Air / Boost / Emissions 2
M Vacuum Question General Discussion 36
yaahoos Vacuum leak causing rough idle? Fuel / Air / Boost / Emissions 3
78_Monte970 Help needed: vacuum lines Transmission / Rear End / Driveline 7
dickeymoore Mechanical secondary or vacuum secondary carb for daily driver Fuel / Air / Boost / Emissions 19
pontiacgp Vacuum Pump Brake Bleeding General Discussion 19
J 85 442 vacuum Oldsmobile Cutlass / 442 / Hurst/Olds 6
pagrunt Air brake hose for emission/vacuum lines? Engine / Swaps / Driveability 3
S vacuum gauge for edelbrock carb General Discussion 3
565bbchevy Vacuum Canister OFF TOPIC 3
buhler86 Cruise Control and LS G-Body LS Swap 4
M Control arms Frame / Chassis / Suspension / Steering 1
leefybeaver FiTech Transmission Control G-Body LS Swap 5
pagrunt My home made rear sway bar/control arm inserts Frame / Chassis / Suspension / Steering 0
Tschafer94 Control arm swap Frame / Chassis / Suspension / Steering 8
G T type 8.5 with 3.73s and sway bar, full set of brand new umi control arms G-Body Parts For Sale / Trade 9
81_El_Homewrecker Cruise Control Stalk Rating Electrical / Ignition / Starting 10
lonewolf Placement of control knob for passenger side remote mirror Body / Trim / Paint / Glass 5
ed1948 Adjustable Upper Rear Control Arms Frame / Chassis / Suspension / Steering 16
melloelky boston CL ad,not mine.good deal on rear umi control arms.upper and lower General Discussion 0
O. D. Showtime REGAL Digital Climate Control Buick Regal / T-Type / Grand National / GNX 17
K NIB Spohn Front upper Tubular Control Arms 1978-1987 GM G-Body G-Body Parts For Sale / Trade 8
S Help- Looking for Cruise Control Connector or Harness Electrical / Ignition / Starting 4
S 1983 Cruise Control Multifunction Switch Wiring Connector Oldsmobile Cutlass / 442 / Hurst/Olds 1
FastCraig Searching for a particular rear control arm bracket Frame / Chassis / Suspension / Steering 25
TURNA Heater control delete plate General Discussion 7
T FOR SALE UMI Performance Control Arm Reinforcement Brace Kit 3028-B G-Body Parts For Sale / Trade 5
bazthespazz Replace bulbs behind heater & A/C control. How-To's / Knowledge Base 4
gnvair Can anyone definitively say that the front lower control arms from an S10 will work on a 78-88 A/G body?; Frame / Chassis / Suspension / Steering 22
1320John$$$ Not so quality in control General Discussion 9
L upper control arm question Frame / Chassis / Suspension / Steering 17
L Upper control arm shaft help Frame / Chassis / Suspension / Steering 3
C non ac control head Cooling / Heating / AC 9
O Cruise Control not working New Users 1
Hubb79 Upper control arm swap Frame / Chassis / Suspension / Steering 4
Hubb79 Upper control arms Frame / Chassis / Suspension / Steering 2
69hurstolds CUTLASS More Quality Control issues from 1985. And an interesting decal find on the AC Compressor Oldsmobile Cutlass / 442 / Hurst/Olds 37
Jackdiablo S-10 upper and lower tubular control arms Chevrolet El Camino / GMC Caballero 20
84dragcutlass Control arm bushing removal Frame / Chassis / Suspension / Steering 20
D Rear control arm? General Discussion 13
J Dakota Digital Cruise Control in 84 Hurst/Olds Oldsmobile Cutlass / 442 / Hurst/Olds 3
Similar threads
