Anyone use the friont drive accessory kit 19355805 from GM and what water pump did you use? I have a 19180610 water pump and I am looking to use this on a LS# that I will put in a 4th Gen Monte SS.
You're right. I looked up that part number you listed and saw it included Vette applications and thought it was the same pump. It isn't. The drive and pump we used is for a C6 Vette. It looks very similar to that CTS-V drive you asked about but i'm unsure of the differences so my posts aren't that helpful, unfortunately. It does appear that the pump you have matches with the accessory drive you posted about.This is the water pump I have. It looks different than the one you have in the pictures. I did see the Vette accessory with out ac and was wondering if the Holley bracket would work. View attachment 114786
