Okay does it connect to the accumulator I have?Low pressure switch
Mines a Monte Carlois that a camaro?
Thanks I think I found itIf memory serves me right, you are reconstructing your air conditioning system which the previous owner removed.
The part you are looking for is the A/C clutch cycling switch. If you had no dryer / accumulator in the car to start with that part is probably missing.
Here is the listing from Rock Auto, though I may have the year of your car wrong. https://www.rockauto.com/en/catalog...ctrical-switch+&+relay,a/c+clutch+switch,4284
I was wonder which one u think I should go with the original or the four season one?If memory serves me right, you are reconstructing your air conditioning system which the previous owner removed.
