Hey guys,
Have you noticed a lot of widespread ignorance about the difference between GROSS and NET ratings? If you aren't aware, the big power GROSS engines from the 60s and early 70s were rated in ideal climate controlled conditions, with no air filter, no accessories, and just test headers. The NET engines were rated just like they go into the car.
That's why a 1969 station wagon with the standard non-performance 350 2bbl and single exhaust is rated at 250hp. Rated with the '72-on net system I'd estimate it at 180hp or 15hp better than the same engine in '72 due to slightly better flow. The performance engines were closer to the GROSS rating cause they actually had dual exhaust, free flowing filters, etc. I'd be willing to guess a '67 Corvette 327-300hp would be around 245hp and the 327-350hp probably around 315hp. So basically the way I see it, the higher you get in performance the closer the gross ratings are. It really gets confusing too because some engines actually were underrated in the GROSS system for insurance. For example, the 396 L78 was rated at 375hp but actually did make about 400 net hp. Those are purely the top performance engines of the day though.
What do you guys think? Those are just my estimates...
