I got a cable from the JY a long while back and I finally updated my windshield to the one with the antenna.
I used the factory location for the cable (center opening & 2 screw holes) and pushed the cable into the cabin before fastening it down with the 2 screws.
But I can't find the other end inside the car! I've removed the glove box, the RH dash trim / vents, and felt up behind the ducting, under the ducting, over the ducting, over the top of the center vents. I've crawled head-under the driver side dash and reached up there too. I'm using a light; if it was visible, I'd have seen it by now.
Do I need to poke it through the (jute?) firewall sound insulation?
If I get this, I'll try and add pictures of where it comes into the cabin.
