Adjustable Fan Control
79MaliCrazz
577
70
Lake Wylie,SC
I bought my Hayden adjustable fan control about a year ago it was working ok now its not working right the control gets real hot ive seen some people say they suck so can anyone tell me of a better dual fan control.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
you can get a thermal switch with two contacts which close at different temps if that if what you looking for. I noticed them when I was going thru the book at Napa. Or if you want them on at the same temp you can run a thermal switch and two relays.
jrm81bu
3,000
48
Antwerp, OH
I've got a Hayden on my Malibu. Been on there for a few years now. It's not as good of quality of one that came with my Flexalite fans. But better than the Flexalite controller that I put on my Blazer.
The one on the Blazer is only rated at 20 amps so I wired in a relay so that the controller never "sees" the load of the fans. It's just the trigger for the relay and is still adjustable.
79MaliCrazz
577
70
Lake Wylie,SC
I called NAPA and i have to go down they said they might have one just gota know what temp i want.
79MaliCrazz
577
70
Lake Wylie,SC
Ok thanks I want one to come on about 180-190 and shut off at like 170
Cutty1
412
2
metro detroit
how do you wire it in the system and where does the thermal switch screw into on the radiator?
Part Number: MBI RF993619
Product Line: Midland Brake Products
Attributes:
Product Application : Horton
Thermal Switch Circuit Type : Normally Closed
Thermal Switch Operating Temperature : 185 Degrees F
Thermal Switch Pipe Size : .500"
FE3X CLONE
2,714
47
48
Ohio
This is how you need to wire EVERY fan no matter what. There's no controller on the market that can handle the current of a fan directly. Other than maybe one of the high dollar electronic controllers. And even then those can only run one fan.
jrm81bu
3,000
48
Antwerp, OH
The one that came with my dual fans took the load for many years and it was a dual fan setup. After it finally gave up I thought about getting another but it was over 100 iirc. So I grabbed the Hayden and it's been running them ever since. It also sees the full load of both fans.
I wasn't gonna chance it on the Blazer though, y book said it was rated at 20 amps but it has 16(I think) stamped on it so I knew it wouldn't handle the fans I put on.
JBreu
2,168
20
38
Livonia, New York
I just ordered my relay harness for the mark viii upgrade I will be doing from Jabin, here: http://stores.therelaycenter.com/-strse ... Detail.bok He's an authorized vendor over on montecarloss.com I talked to him for about an hour on the phone and he knows what he's doing. Give him a call and he'll custome make a harness for what your loking to do ...
