I have a 1979 Hurst/Olds that I put a mildly built 455 in 12 years ago. (The car had a non-original Olds 350/Turbo 350 combo so I wasn't worried about numbers-matching.) I also swapped in an 8.5" rear with 3.73 posi at the same time, but kept the Turbo 350 transmission and a Hughes 2500 stall converter. I don't drive the car on long trips because of the gearing. I'd like to swap in an OD transmission, preferably a 200 R4. I have one out of a 1987 442 (KZF code) sitting in my basement now. Should I consider having it beefed up or just sell it to buy one already done. Who reliably builds the 200 R4 to handle the power of a big block? I need an OD to be able to enjoy the car more. It's a fun car but only when I'm doing things locally. Since I swapped in this power train combo I only drive the car about 700 miles a year or less. 8-10 mpg just doesn't cut it anymore.
Plus, what do you think the engine is making for power? It is a 455 that is .030 over, Edelbrock aluminum heads out of the box (no porting), 10 to 1 compression, Comp Cams Xtreme energy 274H cam, roller rockers, Edelbrock Performer intake, Edelbrock 770 cfm carb, and stock "W" and "Z" cast iron exhaust manifolds into a 2.25 in true dual exhaust. The machine shop that built it for me guesstimated about 350 HP and 475 FT/LBS.
Think that's accurate? I need an OD transmission that will be reliable. I don't plan on taking it to the track but I can't rule out the occasional street shenanigans. Any advice would be appreciated.
