After market efi. Do I need knock sensors
T
Tony1968
Jul 1, 2018
94
39
#1
As stated. Thanks
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
24,191
9,405
Kitchener, Ontario
#3
if you have a factory computer controlled distributor then your engine would already have a knock sensor. If you don't have a computer controlled ignition system then a knock sensor has no place to send it's info.
T
Tony1968
Jul 1, 2018
94
39
#4
Not using stock ecm. Going with Holley or Fast most likely. This is a 6 liter lq4. Can't find information about whether those efi systems use knock sensors
pontiacgp
pontiacgp
Mar 31, 2006
24,191
9,405
Kitchener, Ontario
#5
Like I said a knock sensor involves the computer and timing, it has nothing to do with the fuel injection system so that is why the systems you are looking at don't have any information about a knock sensor. The other thing is if you do not have any knock sensors installed in the block now how are you going to install them?
Streetbu
Streetbu
824
1,385
Central NY
#6
Stock LQ4's use knock sensors. Aftermarket efi systems do not AFAIK....
Northernregal
Northernregal
583
1,647
Red Deer AB
#8
The Holley system hooks into a knock sensor but you don’t have to have it do much in your tune. A general consensus is that you stop making power gains before knock happens. If you add timing and you don’t see a difference then you are getting close to the edge so drop a degree or two.
T
Tony1968
Jul 1, 2018
94
39
#9
so is it your opinion that i can do away with the sensors and replace valley cover with something prettier ?
Northernregal
Northernregal
583
1,647
Red Deer AB
#10
Yup. You could get a Gen IV knock sensor and bolt it to the side of the block if you want to have one there. That’s another option.
Similar threads
