i bought a 2 in cowl fiberglass hood for my 80 Elco that had vent holes cut out of hood and also some of the superstructure removed under cowl....now for the problem... rear of hood won't lay flat because it hits the rivet on the hood hinge and part of the hinge is hitting back corners of hood....are there different hinges that people with same problem used ...I know i can remove some fiberglass but that might make the tip of hood flimsy ...any other suggestions or comments.
