I was searching around for someone who makes caps to repair rear frame rails when I found someone in Canada who actually sells whole rails with body mounting pieces. They don't seem too expensive either considering the fact of what they are.
I contacted the seller and he replied back twice immediately with answers and several installation pictures on a few different cars. He said they are 29 3/8" long, and overlap on top and on the bottom. The sides have a channel that is inserted into the original frame to make it stronger and so that the sides can be welded flush.
I work in a bodyshop and the system seems reputable. We actually end up sectioning frame rails all the time on newer cars with thinner metal. There are several rules of what is right and what is not, but basically, I-CAR states that as long as there is a sleeve inside the sectioned area and the repair doesn't extend into the kickup area, the repair is acceptable. The biggest challenge is getting a quality weld. Full frames rarely get replaced anymore, I've only seen it done once on a Ford Sport-Trac, and it was surprising the insurance company paid for all the labor that went into that.
So anyway, has anyone done this? I originally stumbled across this on someones Car Domain page of a modified Monte Carlo SS, and then later found a website where somebody with a Grand Prix did it. Both were in Canada where rust seems to be very bad much like the northern rustbelt of the U.S. for G-body frames. The rear part of the frames on these cars are not very well made, at least on the cars I've inspected. The thin gauge metal coupled with incomplete welds and large holes from the factory don't stand a chance with moist soils and especially road salts. If anything, if done right, I personally think this would be stronger than what was there from the factory, but I'm not real familiar with sectioning full framed cars yet. I'll include the link below.
http://www3.sympatico.ca/conradlozier/
