Buhler86, which engine mounts did you use, and did you do any other modifications. Also which pulleys are you using, truck, Camaro?
Thanks for the information, it helps a lot.I used these motor mounts: https://www.summitracing.com/parts/upi-2406-b and custom made the other side of the mount. I am using the stock truck pulleys. My engine is sitting a little higher because of the mount setup. That allowed me to have stock compressor placement, and stock oil pan. However, closes the hood is tight, cant have the decoritve engine cover on Hope that helps! View attachment 155026
