Air filter question
Rudy913
646
68
New Orleans
I was wondering what is a good brand air filter for my 305 ? I was looking at the spectre but would I need a adapter ?
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
If you have a 4 barrel that will fit
Make sure it has a drop base
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
For either type dual snorkel or the open element i would look on ebay.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
That is false advertising that the open element gives you increased airflow and performance. My air/fuel mixture gauge told me that when I switched from an air cleaner like above to a Gm duel snorkel. The duel snorkel drew in more air than the open element.
Rudy913
646
68
New Orleans
The gm duel snorkel I search cost about $180 where did u order yours from?
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Those top lid air filters look cool but do not perform well.
The problem is they are to thick and the bottom of the lid is to close to the choke horn not allowing the bulk of the filter to provide proper airflow into the carb.
For pictures and shows I used an air cleaner like the one you want.
For the track I will use none, my cowl induction setup or one that looks like the photo below.
You would be better off keeping what you have on it. getting a top that looks like this...
Or a Dual snorkel like pontiacgp said.
axisg
2,685
2,354
YYZ
Grab a stock air cleaner ( or 2 if you can find them ) from a G body Monte SS. They have the factory ducting to pull cold air from next to the battery. If you can find a second one you can make your own dual snorkel Air Cleaner. My car pictured below but I got the idea from a post at MCSS many years ago. I made a thread on here somewhere. FWIW when I ran a holley and an open element filter in traffic my car would surge then stumble. I switched back to the qjet and factory air cleaner and those issues went away.
I picked up a complete ( but very dirty ) MCSS air cleaner a few weeks back for not much money as a spare so they are still out there.
