Air filter
Rudy913
646
68
New Orleans
Are these filters any good?
spidereyes455
784
1,637
Northeastern PA
You'd probably be better off with no air cleaner at all. IMO the foam is too coarse to actually filter anything, and eventually will most likely break down and get sucked into the engine.
6,001
12,685
Avoid avoid avoid avoid. The bigger issue is if the engine backfires, the foam element catches fire, melts and simultaneously gets sucked into your carb and intake. One backfire can ruin your carb, intake, heads, and potentially even more.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
NO!!!!!!!!!!!!!!
Unless you are planning an insurance job to burn your car to the ground.
yourownself
336
38
stoughton, ma
They did an engine masters episode where they compared air filters and all of the guys unanimously agreed that the only good thing about it is the nostalgic look. They ran a variety of air filters on an engine on a dyno, and this one robbed the most power.
8,819
7,766
Melville,Saskatchewan
I actually had melted spots on one. There is a reason it is so cheap.
565bbchevy
9,611
12,670
Michigan
They are extremely restrictive, I ran one many years ago because of hood clearance issues and it suffocated the engine and I ended up installing a 14 x 3 air cleaner and a scoop
Rudy913
646
68
New Orleans
Can someone tell where can I buy a smaller air filter ? I search pic on google but what size are they
