Air not blowing out vents
Kylec345
41
8
I have an 85 cutlass and the air is not blowing out the vents and not even the defrosters also the passenger side floor and rear passenger floor are soaked with this oily substance any thoughts on these two?
Diesel guy
22
Arkansas
Check for leaking heater core and check for vacuum lines disconnected underhood @ the reservoir ball
Diesel guy
22
Arkansas
Mine mounts next to the drier for the a/c on the same bracket. And has 2 Hardlines for the vacuum. Both are sort of a gray and very brittle .
MrSony
6,824
6,724
Des Moines, Iowa
Dip a piece of white paper in the liquid. If its green, its coolant and your heater core is bad. Its not hard at all to replace, it's all underhood. If you didn't have the liquid issue id say your vacuum lines are damaged or missing, but start with the heater core first.
