Because the Monte has developed some surface rust I started investigating alternate means of removing rust. I am talking about not using a mechanical means (grinder or wire wheel or the like ) as I hate the mess it makes. Basically this means chemical in one form or another.
Vinegar, Citric Acid, Muriatic Acid, and Aluminum Foil (here is how that works https://www.reddit.com/r/LifeProTip..._get_rid_of_rust_by_rubbing_it_with_aluminum/).
1. A straight vinegar soak for 2 hours did nothing - 24hrs might yield a result;
2. Didn't even try Citric Acid might make a good paste for a vertical surface (could mix it with flour);
3. Muriatic by itself works well after just a few minutes when applied and gently agitated with a toothbrush ( but doesn't penetrate well - a wire brush can be used to break up scale);
4. Aluminum foil with vinegar took a massive amount of elbow grease to cut through to a level surface (it didn't so much as leave a noticeable scratch, the scratches shown were from the previous owner hand sanding off the original paint);
5. Muratic acid, followed by aluminum foil and vinegar (cuts down to the next layer), and more muriatic acid seems to do the trick (very smooth and level);
6. Is just muriatic acid, and vinegar/foil rubbed over the roof, you can see that the paint is still there. (same degree of material removal occurred);
7. The tools I used.
I am going to strip portions of the car with paint stripper, then treat with muriatic acid, vinegar and foil, muriatic acid again, and finally some POR-15 Metal Prep (to create a zinc phosphate coating), then primer, minor bodywork, and paint.
Should be interesting.
NOTE: I strongly recommend that if you are going to use muriatic acid that you use as little as possible, meaning put just a few mL into a suitable container and don't get any more until you need it. A little goes a long way and work slowly. This will reduced the risks to your person (noxious fumes and physical damage), and makes clean up/control easier in the event of a spill. Also keep a neutralizing agent handy - I have baking soda within arms reach. PPE is huge too - use a respirator (in a well ventilated area), gloves, and eye protection.
If you are in a rush - just get out the grinder.
