Alternator going bad?
G
Gremlinsteve
237
225
#1
Reason I'm asking is I just replaced my alternator
It started showing a discharge most of the time on the factory gauge
So I replaced it and I'm showing a discharge still
At idle it's dropping down to 8-9 volts indicated
And at 2500 rpm cruise it shows a 12-12.5 area tops
Measured at battery terminals at idle I'm seeing 12.22 volts
Is the new alternator bad also?
Streetbu
Streetbu
824
1,385
Central NY
#2
Sounds like it. You should see 14.3v all the time...
melloelky
melloelky
872
1,286
mass
#3
With the engine running carefully take a screwdriver and place it on the back of the case.if the driver is strongly drawn towards the back it's charging.
Z
Zspoiler
Jun 3, 2018
85
54
#4
Take it back f you are not satisfied with it.They can bench test them at the store.And if you still have issues,Then you know its not your altrenator.
565bbchevy
565bbchevy
5,921
4,934
Michigan
#5
I would do all of your testing with a volt meter and test from the output terminal off the back of the alternator and disregard anything your factory gauge tells you
airboatgreg
airboatgreg
1,413
1,305
What kind of car?
Alternator type?
gauges or idiot light
G
Gremlinsteve
237
225
#7
Off the alternator I'm getting 12.2 volts
Not the 14-15 I would expect
G
Gremlinsteve
237
225
#8
12si alternator
Gauge
El camino 1987 model
airboatgreg
airboatgreg
1,413
1,305
make sure you have 12volts to rear of alternator and to red wire that plugs into regulator. Brown wire is turn on so unplug 2 wire connector, start propulsion plant and see if you have 12 volts. With engine running see what your voltage is at the rear output, if it happens to be real high you have an open wire. Rare but something to think about.
If all good bad alternator.
G
Gremlinsteve
237
225
#10
Ok
Similar threads
