Alternator on Serpentine System
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I have the F body sepentine set up and I have a CS 130 alternator whch sits too tall and the inner panel of the hood hits it. I "modified" the inner panel hood but that hood has a bend in it so I'm looking for another hood and want to fix the issue with the alternator. Is there a small case alternator with a high output that will mount on the bracket?
:popcorn:
  • Wow
mikester
2,904
3,641
Small town NY
Crap, Im trying to get the wiring done in my 83. Now I have to see if Im going to have the same issue !!! YIKES !!!!!
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,990
Socialist NY
The small ones burn out to fast
  • Sad
mikester
2,904
3,641
Small town NY
:popcorn:
Is the F body set up the same as the one on a crate motor ? I looked at the alternator just now and it looks like it should clear.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I may have made a mistake, I might be using the CS 144 as an upgrade to the CS 130 I had....
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
Is there a big difference in size between the two ?
I have to go take a look to see what I have cause the mounting locations for the bolts on the 144 are not the same as 130 so the 144 should not fit the serpentine bracket..... :unsure:
84cutspreme
1,143
151
cs130 is considered a small case, cs144 is larger and most have issues with hitting valve cover unless stamped steel. I have cs130 on my sbc in cutlass with serpentine system and does not hit the hood
