The Aluminum Drive-Shaft was removed from an 1999 Chevy S-10 ZR2 (4.3L engine, 4x4, and ext cab). I pick up the AL drive-shaft for $40. I purchased 2 universal joints ($8 each, with my military discount). The Universal joints for both drive-shafts are the same p/n, according to the Oreilly's parts guy.
Stock Steel Drive-shaft stats: Length 54 inches, Weight 12lbs/without yoke, 2.5 inch dia. (my car is a plain-jane, 1981 Cutlass Original 350 Diesel, Th-200, 7.5 rear)
S-10 Aluminum Drive-shaft stats: Length 53.5 inches, Weight 10.5 lbs/without yoke ( -1.5 lbs less), 4 inch dia.
The only thing you need to do, is use our yoke off your steel drive-shaft. The S-10 yoke is huge compared to the G-body's yoke.
Being it is 4 inches in dia my Stock exhaust is really close to hitting the drive-shaft. Its was hitting where the exhaust pipe crosses under the drive-shaft too switch from the passenger side to the driver side. No biggie really.
Now being, all I saved was 1.5 lbs. Was it worth it. NO!!!...But, I think this drive-shaft is a lot stronger being 4 inches in dia. So looking at it in Weight and Strength, its worth it for what I have into it. IMHO
EDIT: Altho I was excepting less weight. Doing a little bit more research. The 4th gen f-body aluminum drive-shafts are only 3 inch dia. And they have problems in the racing world for twisting. So maybe this 4 inch is actually a really nice upgrade for strength to weight for aluminum.
You decide!!!!
Steel is .5 inches longer
Steel 2.5 inches dia, AL 4 inches dia
You decide!!!!
