MALIBU American idle
Dezimade
372
116
Boston Ma.
Why am I getting a high rev in park?
I need to lower the idle….. any advice?
Rochester 2 barrel
Already tuned by a diesel mechanic
I am a new 🐝 when it comes to carbs.
Dez
Rochester 2 barrel
Dez
Vacuum leak? I don't know Diesel motors but I assume the carbs work the same. If you follow the linkage for the throttle, you should see a screw, i.e. idle screw, and turning it in or out will move the idle position, changing your idle/RPM. But if it's been fine and all of a sudden your getting a high idle it's more than likely a vacuum leak.
Reactions: Dezimade
Thanks I gather vacuum leak.
