Another headliner
Bonnewagon
Lost in the Labyrinth
10,563
14,293
Queens, NY
I get the foam backed material method and last time the shop did it nicely. But my Firebird used a perforated vinyl material. That would look great but how is that applied? Is it also foam backed? That car is long gone so I can't examine it. I think the board is in very good condition from what I remember.
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
It is usually foam backed, but it is a closed cell, closer to the backer board material.
79 GP 4 speed
448
535
I cleaned my headliner board and got material from Walmart, sprayed it with 3M headliner glue and it still looks good from about 8 years ago. I do drive with my t-tops out quite a bit.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,174
9,776
Gainesville, Fl
Mark,
I'm not quite sure how the perforated fabric in the Firebird would be applied, but I would think it would be almost free floating, perhaps suspended by bows.
When I did the headliner in my P car it was a perforated vinyl that was stretched over, and if I recall used bows to help suspend it....like a VW bug...which I 've also done a headliner in many moons ago.
69hurstolds
8,184
17,566
Some late 70s Firebirds/Camaros had the perforated headliner material. It was kinda like thin vinyl with holes in it. Why did it need the holes anyway? But it had spongy foam or foam like stuff on the backing with the fiber board. You would apply this the same way as a typical G-body fabric headliner, I would imagine, but likely apply the glue with a brush or something on the back side of the headliner material perhaps? You wouldn't want to get glue up in the holes and have it come out there. It likely wouldn't if you "webbed" the glue in place on the back of the foam and didn't put it on too heavy. Because you sort of have to let the glue dry to a tacky state anyway. Once you put the two together it's instant bond time.
Bonnewagon
10,563
14,293
Queens, NY
Jack the '67-'69 Firebirds had the steel bows and some decent headliner material. I think that carried over to around '75 or so. Then it was glued to cardboard just like our G-bodies. My '77 TA had very nice black perforated vinyl that I would not mind having in my wagon.
