Current carb number is 17083204.
I have the original that will be on the list for a rebuild, but not sure when I can dedicate time to that. I prefer this to replacing and taking in back to original since very little has been touched on this car. Just rebuilt power steering pump when I could have just replaced it in minutes!
You can send the Olds carb to Sean Murphy Induction, very good rebuilder. If you want to do it yourself I suggest getting a kit from either Qjet parts or Cliffs Performance. Most local parts stores carry cheap low grade rebuild kits that contain generic spec parts that aren't E10 proof.
The 7th digit on your carb is 0, indicating it is a Chevy carb and is a incorrect application. A correct Olds carb would have a 5 in the 7th digit. Qjets are application specific carbs, they are setup and built for individual applications, unlike aftermarket carbs that are near universal application. The idle circuit in Qjets is the most application specific area of the carb. Chevy Qjets have more idle air bypass than Olds Qjet and very different air bleed setups. You will never get a Olds engine to run right with a Chevy carb, especially idle and low speed.
Don't know why someone would install a incorrect Qjet for? That red wire isn't stock, somebody hot wired the idle kicker since Olds are supposed to use a ISC, not a kicker solenoid. Plus I see some disconnected vacuum lines, somebody really fooled around.
