Another Radio Question
M
mikester
967
781
Small town NY
#1
Forget my original thread about the OEM/Alpine radios. This is making me nuts.
This morning I spoke to the owner of a stereo shop that told me I needed the two little brackets off of an OEM radio so I could mount the Metra box into the Monte dash. I went to the local yard and pulled them off of a factory Delco radio that was in a Cutlass. Easy right ? NOPE. Not for me.
I put the two brackets on the plastic box and now its too wide to fit into the opening. Probably by at least 3/16".
I assumed the Cutlass dash and the Monte/Malibu had to be close in dimensions where the radio mounts. I guess not.
I have some of the textured plastic left over from the gauge mount that I made but to be honest I dont want to spend hours fabricating something if theres something already made to do what I need.
For Monte owners, do the OEM radios have the same plastic bracket on the sides holding them into the dash ? Black plastic angles that are held on with a 10MM nut ? If not what do they have ?
Are Cutlass radios held in with something different ? Did I wind up with the wrong stuff at the yard ?
This is all thats left as far as the dash. I need to get it finished so I can move on.
Anyone ?
I dont want to use an OEM radio since I have these two Alpines.
W
Wageslave
803
829
Anyone ?
The ones in my Bonneville are basically a piece of sheet metal with a 90 degree bend in it and 2 tabs to lock into the slots on the side of the factory radio. There are a few variations out there, but if the screw holes on the outside line up and the bracket does not have a built in angle, then you should be good. Could it be as simple as the bolt that mounts the brackets sticking out too far?
M
mikester
967
781
Small town NY
#3
The bracket needs to have an angle so it can attach to the sleeve from Metra. The brackets from the Cutlass are thick plastic. Maybe I need to find a set in metal. I have a stamped metal one from my 81 but its totally different.
I have these from the Cutlass. Makes everything too wide.
001-jpg.86615
I also have one of these. Not even close.
158390464_1978-87-delco-radio-mounting-bracket-elcamino-monte-jpg.86617
W
Wageslave
803
829
Mine have the general shape of the big one, but are physically smaller.
Luckily, mine is out of the car right now:
img_20180410_235046-jpg.86618
img_20180410_235038-jpg.86619
img_20180410_235029-jpg.86620
MrSony
MrSony
4,452
2,779
Des Moines, Iowa
#5
Mine look like this:
M
mikester
967
781
Small town NY
#7
M
mikester
967
781
Small town NY
#9
The plastic Cutlass radio brackets are unique to the Cutlass. Monte Carlo had stamped steel. This is the issue.
Thanks for the replies guys ! I just got back from a different yard that had a really hammered Monte in the back corner. I was lucky to find the original radio on the rear floor covered in junk. Sure enough, it had the metal brackets. I got them for $5.00. It looks like its going to work !
W
Wageslave
803
829
I hope it works out for ya!
Similar threads
