Since I put the lowering springs on lm thinking of cutting a little off the front springs, so I was crawling around underneath and noticed that the front sway bar is now tilted upward pretty good.Do I need shorter end links now or is there such a thing.It also looked like the back springs are so compressed it appears that 4 of the coils at the top of the spring are actually touching each other with only 2.5 coils to compress when you ride over some bumps in the road.
