CUTLASS Another tail light/turn signal post 🤓
Eddie Cutlass
Eddie Cutlass
May 3, 2020
51
San Diego
What’s up GBody world! Been searching around the site and I appreciate the past and current post to help us dial in on electrical issues.
Here’s my situation: I have an ‘85 Cutlass Brougham Sedan with the right tail light bulb only working when lights are turned on. Doesn’t light up when you apply the brake or when signaling right. Changed the bulb (1157) but still the same. No brake light or turn signal flashing...only park/night light. Other lights not working are the front left bumper turn signal (side turn all and fender light works and so does the tailight). And hazard lights not working (nothing happens when hazard button is pushed or pulled. Feels “thick” when pushing in hazards) All other side marker lights and some lights are working.
The sockets looked yellowish/light orange, so I ordered new bulb sockets for both the right rear and left front bumper (Rockauto), but wondering what else I should check in the mean time?
Would any stereo/alarm wiring cause any of the bulbs to burn out or not function properly? the previous owner seems to have wired in an alarm and aftermarket stereo before and it’s a hack job (previous owner passed away and i got the car from an auction).
I have noticed when I turn on the lights at night, the left turn signal indicator on the dash stays lit. (I’m guessing from reading other post, it’s from the amber bumper bulb not working?)
the gauge cluster lights work (except the check engine light...that was on when driving the car home and it turned off after driving for 400 miles or so, but doesn’t cycle or turn on when using a paper clip jumper) ordered bulb for that too, but that’s for another thread and another day :)
Thank y’all in advance!
blk7gxn
blk7gxn
853
Sorry to hear about your issues with the lights, never fun tracing electrical issues. My guess is that both brake switch and turn signal flasher can't be bad at the same time, chances are very slim ( not saying you wouldn't have my luck though ;) SO, the only thing with a common denominator would be GROUNDS. Just my educated guess here, smart move on socket replacement, seen those go bad too and do the same thing!
Reactions: Eddie Cutlass
Eddie Cutlass
Eddie Cutlass
May 3, 2020
51
San Diego
Thanks!
Update: So I didn’t clean any grounds (they all seemed clean and making solid contact). But I did clean out the twilight socket. Had old dried up grease build up. Scraped all that out, plugged in new bulb and it works! Now I have brake lights, turn signals and park/night light all working. Tried the same on front bumper signal, but still nothing. Changed bulbs and cleaned out socket, but unfortunately might be a bad socket. Didn’t notice any wires damaged. hazards still don’t work. (Can’t hear them either). I’ll replace front bumper socket when it comes in and see if that was the issue.
Reactions: blk7gxn
Eddie Cutlass
Eddie Cutlass
May 3, 2020
51
San Diego
Update 3pm PST: hazards. Hazards seem to be the only switch not working. Do hazards have their own designated fuse? Thanks in advance.
popeye1978
popeye1978
140
I think Hazard Flasher is the problem
  • Turn signals now work and as Hazard Switch is part of the Turn Signal Switch, low probability one part would break and the other wouldn't (though you've reported the Hazard Switch doesn't feel right)
  • Brake lights and hazards get power from the same fuse; as brake lights work the remaining component is the Hazard Flasher
Olds G's
Olds G's
40
CT
I agree with popeye1978. Here is the wiring diagram from the factory G body electrical troubleshooting manual. Yes there is a fuse to check per this print.
Eddie Cutlass
Eddie Cutlass
May 3, 2020
51
San Diego
Right on! Thank you. I’ll head out and grab a new flasher and try that!
Reactions: blk7gxn
fleming442
fleming442
9,883
You need to verify voltage at the column; my money is on the turn signal switch. The white from the brake switch feeds the rear section of the turn switch, then is distributed to the yellow and green. Am I correct to assume the turn signals do not work as well? If there's no hazard or brake, there shouldn't be turn, either.
Also, on the ground side of things, check the ground behind the drivers side rear light, in side the trunk, where the ribbon cable meets the rear light harness. I doubt that's it, but worth looking at.
Eddie Cutlass
Eddie Cutlass
May 3, 2020
51
San Diego
Hey Fleming442, so all the lights and turn signals work...the only thing not working are the hazards. The switch functions, but no flashing of hazards. All other lights work: brake, Night/park, turn signals, side markers, etc. (Front bumper socket might be bad, so I’m replacing that when part comes in)
Thread starter Similar threads Forum Replies Date
pagrunt Another big kid-little kid project General Discussion 0
Texas79cutty Another g body G-Body LS Swap 0
corvettez06 Another missing piece.... 8.5 Rear end G-Body Build Threads 9
lilbowtie Another anniversary General Discussion 12
dfast1 One LS out another one in G-Body LS Swap 17
-83MONTESS- Another kick in the nuts General Discussion 42
lilbowtie Another low mi - hi $$ General Discussion 8
gnvair Another odd ball 4 speed Malibu for sale (not mine) Chevrolet Monte Carlo / SS / Malibu 20
cardude Yet Another Old Guy!! New Users 22
HAFROD Another dash vents not working question Cooling / Heating / AC 6
TURNA Another "custom" Camino General Discussion 13
pagrunt NAPA, another home for Craftsman?!?!?! General Discussion 9
GuysMonteSS Another Season Is Over... General Discussion 4
jlcustomz Another 2010 camaro nose el camino Photos, Videos, etc. 2
Bonnewagon Another FRAM story General Discussion 50
jlcustomz another custom for sale. Photos, Videos, etc. 4
Daca214 yet another AC question General Discussion 5
A Another newbie New Users 7
69hurstolds CUTLASS LEAD- ANOTHER ONE (post #9)!- UNICORN Olds part- 87/88 Front Nose Emblem F/S Fleabay NOS. Not for the faint of heart. $$$ Restoration 11
wskirvin CUTLASS Another interior thread Interior 5
JAMCAR223 Another great GBody parts find - This is one of my better ones General Discussion 10
TURNA Another one bites the dust...Maple Grove General Discussion 11
LeftLaneOnly 70 442 tail light set of four G-Body Parts For Sale / Trade 4
P Power Tail Gate - Weak? Wagons! 9
442kid 1987 Monte SS parts For Sale Sport Steering Wheel, Tail Lamps and 200R4 T Handle Shifter Set up G-Body Parts For Sale / Trade 1
C tail light lens and center console Wanted 10
C tail lights Body / Trim / Paint / Glass 35
08Malibu Malibu Tail light filler color Body / Trim / Paint / Glass 8
Tuffregal83 Nos tail gate weather strip Wagons! 17
G Tail lights wanted General Discussion 0
Yogi NO TAIL LIGHTS/BRAKE LIGHTS /SIGNALS Wagons! 15
Jims442 442 No tail lights Electrical / Ignition / Starting 19
olds307 and 403 I may message him about the tail lights General Discussion 0
Steve Bakken Tail shaft interchange th200, th350 Transmission / Rear End / Driveline 2
DSPbuilt Cutlass tail lights (possible group buy) Oldsmobile Cutlass / 442 / Hurst/Olds 16
Hubb79 1979 chevy malibu tail light harness Chevrolet Monte Carlo / SS / Malibu 0
xylorex 78-80 Monte Tail Lights Chevrolet Monte Carlo / SS / Malibu 0
A MONTE CARLO Check Engine light Chevrolet Monte Carlo / SS / Malibu 2
K NSS and Reverse Light Circuits Electrical / Ignition / Starting 4
Caballero 81 EL CAMINO Temperature light New Users 4
MalibuDavyou5 Oil Choke Light. Engine / Swaps / Driveability 16
Olgambler84 CUTLASS Trunk light Interior 1
8 Map Light Mirror G-Body Parts For Sale / Trade 2
J LED light conversion help General Discussion 4
B Led light conversion kit General Discussion 1
565bbchevy Does this LED Bulb Fit A Standard Dome Light. General Discussion 8
hangar401 Light Stuff New Users 7
J Idiot light wiring help Chevrolet El Camino / GMC Caballero 0
MrSony REGAL Part Number for Bumper Light Socket Gasket? General Discussion 25
CrammerGrammar69 PONTIAC Why is Light blue so hard to find Interior 40
Similar threads
